Hi All,
There is an issue with below scenario.
The user is active in windchill, and he has active license. He tries to login to Windchill with correct credentials. Even after entering the correct credentials, that credentials dialogue box keeps on popping up again and again which stops him to login to Windchill. Account wise, everything is fine.
Please suggest the resolution.
If possible to edit your title of your post better, it would make things clearer. Issue lies with your webserver and LDAP. Check the webserver logs. Can you describe which LDAP your are using? Is this the only user who is experiencing issues?
corp ldap.. two users are facing this
Issue is likely there. Contact admins for that system. Look in HTTPServer for logs folder on the PDMlink server. I've seen it were something as simple as logs filling up on the LDAP server (AD) would cause it not to function properly. If nothing on your webserver changed, its not authenticating users and its only a matter of time before more users have an issue. They are likely cached for the moment,
how to check web server logs
Under Apache (HTTPServer) folder/logs, you 2 logs one access and the other is error
Hi @PK_10753886
Contact admin, that the two users are not used same user name.
It can happen if one user has a unique name and an another user has set a alternate name to the same unique name as the first one.
Then no one can login.
example>
User1 has unique name : userX
User2 has unique name: userY and also alternate name userX
PetrH
i checked it, but it looks fine, they have unique names
Hi @PK_10753886
the names have to be unique and system do not allow to create not unique user
but the alternate/alternative name then there is problem.
User can have 4 alternative names.
Have you checked the alternative name columns?
PetrH
check these articles https://www.ptc.com/en/support/article/CS366967 https://www.ptc.com/en/support/article/cs389384
How is your setup , HTTPS, reverse proxy........
