windchill stopped
ptc-16601
2-Explorer
windchill stopped
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.1.0
We have been having to restart Windchill every 2-3 days, But now we can log in but nothing opens, page never populates.
Here are the errors that I faced
none
5 REPLIES 5
That is not enough information for anyone to assist.
Restart Windchill and review the latest Method Server logs.  What errors are reported?
Does Windchill fully start?  There should be a "Method Server Ready" line in the Method Server log4j file.
What database do you use with Windchill: SQL Server or Oracle?
What LDAP are you using: WindchillDS, OpenDJ, corporate LDAP?
Hello @ptc-16601
Thank you for your question.
 As mentioned by @mmeadows-3, I'd like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
It will be helpful to upload the complete ServerManager and Methodserver log file under <Windchill>/logs
I'd recommend opening a Support Case with PTC. This would be a high-priority issue
rdowns-2
(To:ptc-16601)
Typically the only time I see windchill start but the page not load after you login is when you are not configured right for http vs https. That can happen if you have had the system down and put it in http to do loadfromfile or something like that and then not put things back right. Check your wt properties to see how you are set.
