windchill super big bug
TB_10966080
Apache Tomcat all thread, sometime hang
SocketInputStream.socketRead0 ,but cpu is very low。
os Windows server 12
windchill version 10.2 m230
Sometimes the CPU of the two front-end method servers is somewhat increased, but they do not perform gc at the same time. The same point is running this code SocketInputStream.socketRead0 。It is a system-level snow and does not involve specific operational functions.
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(SocketInputStream.java:152)
at java.net.SocketInputStream.read(SocketInputStream.java:122)
at org.apache.coyote.ajp.AjpProcessor.read(AjpProcessor.java:312)
at org.apache.coyote.ajp.AjpProcessor.readMessage(AjpProcessor.java:367)
at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:118)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
- locked org.apache.tomcat.util.net.SocketWrapper@4cc1fe0b
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:65)
at java.lang.Thread.run(Thread.java:745)
at org.apache.tomcat.util.threads.TaskThread.run(TaskThread.java:103)
Locked synchronizers:
- java.util.concurrent.ThreadPoolExecutor$Worker@4b1e072
i give  problem code:
"ajp-bio-8011-exec-22" Id=10442 daemon prio=5 RUNNABLE (in native)
Blocked (cnt): 1978; Waited (cnt): 1366
CPU nanos: 172000000000; User nanos: 151890625000; Bytes allocated: 27385700440
There is not enough information to assist you. You did not include Windchill version or OS. Let the field know what you've tried or if this is related to a certain action. The partial error message you posted is very generic and not helpful. I would also not classify this as "super big bug" since it may just be a tuning issue.
i find no tomcat connector timeout value.please tell me how change the timeout value
URIEncodingacceptCountaddressajpFlushallowTraceclassNameconnectionLingerconnectionTimeoutenableLookupsexecutorNamekeepAliveTimeoutlocalPortmaxHeaderCountmaxKeepAliveRequestsmaxParameterCountmaxPostSizemaxSavePostSizemaxSwallowSizemaxThreadsminSpareThreadsmodelerTypepacketSizeportprocessorCacheprotocolprotocolHandlerClassNameproxyNameproxyPortredirectPortschemesecretsecuresslProtocolsstateNametcpNoDelaythreadPriorityuseBodyEncodingForURIuseIPVHostsxpoweredBy
UTF-8
100
true
false
-1
-1
false
Internal
-1
8011
100
-1
-1
8388608
320
8
16384
8011
200
AJP/1.3
org.apache.coyote.ajp.AjpProtocol
0
443
http
false
STARTED
true
5
true
false
false
timeout not set.how change the value
 every 2 hour snow,but no gc
