During the Import data via Control-panel, you can enable the "Reject File" and "Skip File" log, see below screenshot, and then check the log files to see if there are any entries are skipped or rejected:
This will probably do it.
Specifically...
Migration is an export/import process.
1. From WindchillDS Control Panel, export the remaining LDAP structure and EXCLUDE attributes entryUUID, createTimestamp, and creatorsName as these are read-only in OpenDJ and will not import.
Hello @JH_8610616,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
