workflow template administration page is blank.
ZL_10908440
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.10
8 REPLIES 8
Hi, Do you mean that there is no list of available WF templates? Please check this with any admin login. Could be ACL issue. Cheers Hari
ultilities->workfolw template administration->template->edit,the windows is blank with no content.
This is due to Java applet incorrectly working.
You need to go give permissions in the java configurations.
There is also a preference to use Webpage without the legacy applets.
pls check the above in help document.
Out of office today.
Cheers
Hari
I have added WindchillUrl in the java control panel -> safety.
And how to use Webpage without the legacy applets.
HelesicPetr
(To:ZL_10908440)
Upgrade the Windchill to the newest version.
You've written that you are using 12.0.2.10 but my dev Windchill version 12.0.2.7 does not use the java applet anymore for Workflow administration so I guess that you are on a previous version then you've mentioned.
PetrH
Yes, it's version 11.0. I put in the wrong information
HelesicPetr
(To:ZL_10908440)
Hi @ZL_10908440
So you need to use an explorer that supports java applets and grant an access to the java applet.
Google search helps 😄 https://www.lifewire.com/how-to-enable-java-in-chrome-4770854
PetrH
Hi ZL_10908440,
Did you check kb articles ?
KR,
Charles.
