Hi all,
we have a PDMLink 8M050 installation, and some Products containing 30K+ objects. Navigating through the folders of those products, users get a page limit exceeded error (even if the user have rights to see only 15 items inside the product) and some of the subsequent navigations through other folders return erroneus "file" lists too... (it seems to query for all the objects and then filter the result with the rights of the user)
Talking with PTC, they said to use wt.folder.pageLimit property (default to 15000), but this could affect the performance of the system. The other approach would be to use wt.folder.OneLevel property, which is very "ugly" for the users because it is not a "natural" navigation through lots of folders.
I know that PDMLink 9 modifies the navigation through folder, but I would like to know how you manage this kind of problem in your installations. Perhaps someone has anoteher solution for this, or someone is working with a bigger pageLimit without decreasing its performance...
Any comment will be apreciated. Thanks.
Iker Mendiola
Prambanan IT Services
http://en.prambanan-it.com
Iker Mendiola - Prambanan IT Services |
