wvs.properties publish.usesPublishRules values
WT_10157238
6-Contributor
Can anyone tell me the allowable values for publish.usesPublishRules in wvs.properties? Mine is currently set "=ARBORTEXT" I see in article CS81396, it says to use "=ARBORTEXT PROE" for Creo publishing. I need to set it up for both Solidworks and Creo. Should my value be "=ARBORTEXT PROE SW"?
avillanueva
22-Sapphire III
(To:WT_10157238)
you can see them called out in other places in the file but it should be  SOLIDWORKS
cadagent.distrule.cadtypes=PROE INVENTOR SOLIDWORKS UG CATIAV5
publish.cadconvert.ACAD=com.ptc.wvs.server.publish.CadConvertACAD
publish.cadconvert.ARBORTEXT=com.ptc.wvs.server.publish.CadConvertARBORTEXT,useworkerdownload\=$(wt.home)$(wvs.dir.sep)auth.properties,types\=PDF HTML WE
B POSTSCRIPT HTMLHELP SGML XML RTF DMP 3D DMP-INPUT DMP-IMAGE DMP-WEB DMP-HELP EPUB,defaulttype\=PDF
publish.cadconvert.AUTODESK_REVIT=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.CADDS5=com.ptc.wvs.server.publish.CadConvertCADDS5
publish.cadconvert.CADENCE=com.ptc.wvs.server.publish.CadConvertCADENCE
publish.cadconvert.CADENCE_ADW_DM=com.ptc.wvs.server.publish.CadConvertCADENCE
publish.cadconvert.CADENCE_APD=com.ptc.wvs.server.publish.CadConvertCADENCE
publish.cadconvert.CADENCE_SCH=com.ptc.wvs.server.publish.CadConvertCADENCE
publish.cadconvert.CADENCE_SDA_SCH=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.CADSTAR=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.CADSTAR_SCH=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.CATIA=com.ptc.wvs.server.publish.CadConvertCATIA
publish.cadconvert.CATIAV5=com.ptc.wvs.server.publish.CadConvertCATIAV5
publish.cadconvert.CATIAV6=com.ptc.wvs.server.publish.CadConvertCATIAV6
publish.cadconvert.CLASH=com.ptc.wvs.server.publish.CadConvertCLASH,useworkerdownload\=$(wt.home)$(wvs.dir.sep)auth.properties
publish.cadconvert.COCRDRAFT=com.ptc.wvs.server.publish.CadConvertCOCRDRAFT
publish.cadconvert.COCRMOD=com.ptc.wvs.server.publish.CadConvertCOCRMOD
publish.cadconvert.ECADNEUTRAL=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.GALAXY=com.ptc.wvs.server.publish.CadConvertGALAXY
publish.cadconvert.GRAPHICSEDITOR=com.ptc.wvs.server.publish.CadConvertGRAPHICSEDITOR
publish.cadconvert.IDEAS=com.ptc.wvs.server.publish.CadConvertIDEAS
publish.cadconvert.INVENTOR=com.ptc.wvs.server.publish.CadConvertINVENTOR
publish.cadconvert.ISODRAW=com.ptc.wvs.server.publish.CadConvertISODRAW
publish.cadconvert.MATHCAD=com.ptc.wvs.server.publish.CadConvertMATHCAD
publish.cadconvert.ME10=com.ptc.wvs.server.publish.CadConvertSOLIDDESIGNER
publish.cadconvert.MENTOR_EDX=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.MENTORB=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.MENTORB_SCH=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.MENTORD=com.ptc.wvs.server.publish.CadConvertMENTOR
publish.cadconvert.MENTORE=com.ptc.wvs.server.publish.CadConvertMENTOR
publish.cadconvert.MENTORE_SCH=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.ORCAD_SCH=com.ptc.wvs.server.publish.CadConvertCADENCE
publish.cadconvert.OTHER=com.ptc.wvs.server.publish.CadConvertOTHER
publish.cadconvert.PADS=com.ptc.wvs.server.publish.CadConvertMENTOR
publish.cadconvert.PADS_SCH=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.PADSPRO=com.ptc.wvs.server.publish.CadConvertMENTOR
publish.cadconvert.PCAD=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.PCAD_SCH=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.PRINT=com.ptc.wvs.server.publish.CadConvertPRINT,useworkerdownload\=$(wt.home)$(wvs.dir.sep)auth.properties
publish.cadconvert.PRODESKTOP=com.ptc.wvs.server.publish.CadConvertPRODESKTOP
publish.cadconvert.PROE=com.ptc.wvs.server.publish.CadConvertPROE,useworkerdownload\=$(wt.home)$(wvs.dir.sep)auth.properties
publish.cadconvert.PROTEL=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.PROTEL_SCH=com.ptc.wvs.server.publish.CadConvertALTIUM
publish.cadconvert.RSD=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.SOLIDDESIGNER=com.ptc.wvs.server.publish.CadConvertSOLIDDESIGNER
publish.cadconvert.SOLIDWORKS=com.ptc.wvs.server.publish.CadConvertSOLIDWORKS,useworkerdownload\=$(wt.home)$(wvs.dir.sep)auth.properties
publish.cadconvert.UG=com.ptc.wvs.server.publish.CadConvertUG,assytype\=topdown,repiba\=additional_reps
publish.cadconvert.VISULA=com.ptc.wvs.server.publish.CadConvertECAD
publish.cadconvert.WINDCHILL=com.ptc.wvs.server.publish.CadConvertWINDCHILL
publish.cadconvert.ZUKENCR5=com.ptc.wvs.server.publish.CadConvertZUKEN
publish.cadconvert.ZUKENCR5_SCH=com.ptc.wvs.server.publish.CadConvertZUKEN
publish.cadconvert.ZUKENCR8DF=com.ptc.wvs.server.publish.CadConvertZUKEN
publish.cadconvert.ZUKENCR8DGW_SCH=com.ptc.wvs.server.publish.CadConvertZUKEN
avillanueva
22-Sapphire III
(To:WT_10157238)
Check the file wvs.properties.xconf, it has some explanations of the settings in comments and examples of other properties which use AUTHORING_APP
