I want to thank everyone for their input.
It appears that once again PTC has started something, completed only 80% and stopped.
OH well!
I have decided to create a "callout format" that generates everything
and then modify and delete as needed in the hole note.
Thanks again
Fred Matthis
Someone on Planet PTC posted how to edit the hole file to get what you want.
Here is my .hol file to use as a template.
http://communities.ptc.com/thread/33216?tstart=0
http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=41085&KW=hole
Thanks to Martin and whoever started this file that Martin attached.
Attached is a .hol file that works in wildfire 5
I took Martins file and cleaned it up.
I used notepad to edit the file.
I do not use patterns on my holes so I removed the pattern link, it can be easily added if needed.
These files will out put the hole, threads, counters, exit countersinks and counter bores depending on what
you select in the hole tool.
Why PTC didn't do this is beyond me. Once I saw what the ascii characters were it wasn't to hard.
Thanks again to all that assisted.
Fred Matthis
