The content you are trying to access is permanently deleted.
Friend having issues with UV axis in WF3, does anyone have a working 4 axis post, generic or heinz 57.
I notice there hasn't been any feedback on this. I looked for any post-processors that are 4- or 5-axis, and it seems that every time someone asks a question about one, there is zero response. If I recall correctly, there are companies that will create a post-processor for your specific machine. Unfortunately, I have never found a source for general information about making such a thing myself. If I could get a copy of the "FIL" file used to process 4th axis stuff, I'd likely be able to figure out how things are done, etc.
You could also call the company that sold you the Pro/Engineer software, and see if they have any suggestions. They usually will be able to put you in touch with people that build post-processors for a living.
Ken,
the Fil and GPost manuals are in your load point. C:\Program Files\PTC\Creo 3.0\M070\Common Files\x86e_win64\gpost. if you want to try and make one yourself.
Most of the time post processors don't get shared as far as I have seen. If you want someone to custom make one you might try Austin NC directly they might build one for you.
Steve
we created a 4 axis post, works on both Creo 3 and 2001i2
In Wildfire 3 it applies XY as UV, to simplify it uses XY XY instead of XYUV
Steve,
I didn't know they included manuals with the installation. That's cool. I haven't perused the installed gpost directory in years and years, because I have my post-processor files in a permanent directory, so I don't have to worry about shenanigans caused by installing the latest version of Creo.
I've posted some parts of my FIL files on here in the past, to answer questions I had answers for, like when I wanted to "fix" the wildly incorrect time estimates given for drilling cycles (the default is to assume all holes are drilled with one straight shot, no pecking, etc). It's the easiest way to illustrate techniques. Of course, as with most computer programs, many of the ones I've found as examples are horrible messes of incomprehensible code. The hardest part of this stuff is deciphering and debugging the more esoteric calls to POSTF.
I think the main problem is that the user base for the Manufacturing module is small, so we don't see a lot of trial-and-error experiences to learn from. No matter how much I like this tool for difficult programming (like custom trajectory milling on contoured surfaces with a flat endmill), MasterCAM is the most common means of generating NC programs. Oh well.
Hello Kyle,
I think you can take look at below hyperlink, hope that can help you, thanks!!
Mill post
http://support.ptc.com/cs/cs_27/howto/ncgp2646/ncgp2646.htm
Lathe post
http://support.ptc.com/cs/cs_27/howto/ncgp2647/ncgp2647.htm
thanks so much
Mark Rao
