A Basic Question : Why regeneration required in Creo?
SandeepKadam07
Dear all,
There are lots of CAD softwares in market. As per my knowledge, I couldn't find any such regeneration happening in any other CAD tool.
Please share information regarding regeneration in creo
Sandeep
All parametric solid modelers require a regeneration. Some just do it automatically and you never notice it. UG/NX, SolidEdge, SolidWorks, CATIA, Pro/Engineer family (Pro/E, Wildfire, Creo), and Inventor all require regens after a parameter change to update the model appearance.
In my former company have response for diesel engine design. When I edit some component and return to assembly , it takes about 1hour to complete regeneration.
After that happen I decide to edit all components before I press regenerate button. That is the point why regeneration button must have.
(use Pro Engineering wildfire 3 )
If there's no on-demand regen, your work will be interrupted every second, because of the auto regen. The point is to let you finish what you're editing before the model rebuilds.
I got it now...
Thanks all
