I think... I lost a file. Still in same session, dont know how to re-open.
ptc-4416932
3-Newcomer
I was working on a design this morning and had nearly completed it. At some point, I got side tracked with another project and accidentally closed that file in Creo 2.0. After looking at the Object List, I can see that it is still in the session, however I have no idea how to re-open it (facepalm).
Any suggestions would be greatly appreciated.
Just click the "in session" button in the file open dialog and click on the "file name" you are trying to re-open.
By default, if a part or assembly is in session, it will read this before Creo/WF/Pro/E will read the disk.
Not sure about Creo as I'm still on Wildfire 5 but in the open dialog box it should have an "in session" option to the left.
