Windchill structure incorrect when instances used in ProE
I have created one ProE assembly say ASM and checked in to Windchill. To this assembly there is a WTPart attached/associated.
The ProE assembly has a structure as follows where A is for assembly and P is for part;
ASM
|------- A1
|------- A2
|------- P1
|------- P2
The ProE assembly has a corresponding WTPart structure as all the assemblies and parts are associated with respective WTParts.
Now the assemblies A1 and A2 have family table instances as follows;
- A1 --> A11, A12, A13;
- A2 --> A21, A22, A23.
For assemblies A1 and A2 when we check the association with the WTPart then A1 & A2 are the ‘owners’ and the family instances are the ‘content’.
When I use the instance in my ProE assembly i.e the ‘content’ then in Windchill for the ASM structure the WTPart for the instance part is not present. It means whenever I use ‘content’ part in the ProE assembly the Windchill structure is wrong as the WTPart for the instance is missing from the Windchill structure.
Does anyone know what is the reason behind this and how can I resolve the issue?
When the 'owner' is used in ProE assembly then the corresponding Windchill structure is correct.
