I hope some people will find the following ideas of value so they can be added to the software in the very near future.
Most of these I'm sure others have thought of in the past.
Please vote on if you feel they are of value.
Isolate Component(s) By Hiding ALL Non-Selected Components for Temporary Effect (No Layers or Reps)
Allow Creation and Editing of Simplified Reps and Changing States While in Creo Simulate / Mechanica
Add ability to Creo Simulate Fasteners to Work With Tapped Hole Lead in Chamfers & Counter Bores
Creo Parametric Simulate - Add Ability to Edit Model Feature Dimensions While in Simulate
Mechanica / Simulate Edit Load Set Description
Creo Parametric Simulate - Delete Multiple Analysis
Creo Simulate / Mechanica - Add ability to use Fluid Cavities with displacement equations
Don Anderson
Don't forget to vote on your own ideas, Don!
