Cant acess IFX
CS_10278375
Cant acess IFX
I am using Creo Parametric Release 4.0 and DatecodeM140
the intelligent fastener extension does not appear in the "tools" window of Creo. I was wondering how I install or use it.
6 REPLIES 6
Maybe you have the option  intelligent_fastener_enabled set to no. in config.pro file or either in config.sup.
If so, then set it to yes value
BenLoosli
(To:CS_10278375)
The IFX license is an option and costs extra. Creo 3+ comes with a basic IFX license, but you cannot modify anything with files supplied.
Not necessarily. In latest Creo Design packages full IFX is bundled with a base Creo Design Essentials package (along with some other extensions like AFX or Cabling & Piping). It's an extra extension only if you have some older packages and not upgraded them to Design Essentials or higher.
jchelle
(To:CS_10278375)
Dear customer,
As previously said, you need a specific license to access the IDX module from Creo Parametric.
Please can you check if such license is available in your Creo 4.0 session :
> File  > Help > System Information > Configured Option Modules , then check if  IntelligentFastnerExtension is listed.
Waiting your information
Cheers
jchelle
(To:CS_10278375)
Sorry for the typo , I mean IFX
remy
(To:CS_10278375)
To check the installation, browse to Common Files folder and confirm the ifx folder is present.
Another way is to run set-up again.
