I've just installed creo 2 on a new windows 8 PC, and I'm having an annoying issue. While rotating or panning the model view, all datum planes become invisible. They are perfectly visible as soon as I'm done moving the camera, but I find it much easier to position the camera if I can see all the datum planes.
Is this a bug or a setting that I can change?
Help much appreciated!
I found it!
File/ options / model display
Under "model display when reorienting the model", check "show datums"
I found it!
Config option for this is spin_with_part_entities > yes
