Hello All,
Just started using Creo some months ago and I would like to know if there is any feature similar to the design tables from solidworks on creo (excel file whose datum update solid model features and sketches and can de stored in windchill without problems).
Thank you for your help,
The tool in Creo is family tables. The table is stored within the model and will work in windchill.
Check this out for an intro to the functionality:
