How to find assembly component with different unit system?
CS_10428158
8-Gravel
How do I find a component that is set to metric units?  All of my components are set to English units but there are several that are set to metric and when I export it to a step file it creates an error where components that are metric are scaled incorrectly.
tbraxton
22-Sapphire I
(To:CS_10428158)
I am not aware of a system parameter that is searchable for units set in a model.
The most expedient fix for this is to force consistent units in the top level assembly model.
Use the following command sequence.
File > Prepare > Model Properties > Units > Change >Include Submodels > Set
Involute Development, LLC
Consulting Engineers
3 REPLIES 3
tbraxton
22-Sapphire I
(To:CS_10428158)
This fixes everything.  Thank you all models are correctly scaled.
maybe because of English units the volume of English models is "small".
You can use something like this:
Martin Hanák
