Is it possible to merge multiple parts together into one part?
dbarton-2
Hello Doug,
this is for PTC Creo Elements Direct Modeling or Express 6
There are some rules.
Read the help on the topic if you have problems.
Click the black question mark
Enjoy it
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct /Drafting, /Modeling and /Modeling Express 8.0 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
Yes... assemble them and activate the master part.  You can now Merge another part in the assembly into the master (which is now active).  You can do an Add or Cut using this process.  It can also be touchy about what geometry it will try to merge.
Does this apply to Creo Direct?
Oops... I always miss that.  No, that would be Creo Parametric.
Hello Doug,
Enjoy it
Hi, thanks. It is the unite command that does what I want.
