Hello!
I have a question!
How can I create an excluded area in a model?
For example, in this case I want to isolate from analysis the edge of nozzle-shell junction, and is simple.
But I wont also isolate the areas near the edge, using this control.
I select the surface to exclude but running the analysis the software do the calculation of the stress.
Somebody can help me?
Hello Stefano,
did Steven's suggestion with the measure solve your issue?
Then, if you have the time, please go back to the thread and mark his post as Correct Answer, to reflect that the issue has been resolved.
Gunter
