Loading time parts with component interface
dbreen
1-Newbie
Hello everybody,
We're using parts and assemblies with defined component interface. However when loading these parts or assemblies into another assembly it takes a decent amount of time before the part / assembly is loaded and can be placed. We're not experiencing this with components which do not have a defined component interface.
The computers we're using have the following specs:
Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
8.00 Gb RAM
Are there more people who are experiencing these problems? And what can be done to reduce the loading time of parts with defined component interface?
Dave
5 REPLIES 5
Hi Dave,
Have you monitored memory usage for those having issues? I would be curious how much free ram is available during the period of loading the assemblies.
Don
MartinHanak
(To:dbreen)
I only guess that Creo is collecting possible assembling alternatives ...
I suggest to experiment with config.pro options, for example:
COMP_ASSEMBLE_WITH_INTERFACE
values:
   INTERFACE_TO_INTERFACE
   DEFAULT_MULTI
   DEFAULT_SINGLE
   FROM_LIST
   NONE
COMP_INTERFACE_PLACEMENT
values:
   INTERFACE_TO_GEOM
MH
Martin Hanák
Thanks for yor reply! I wasn't aware of the possibilty to change these setting in the config.pro.
I've change the COMP_INTERFACE_PLACEMENT to INTERFACE_TO_GEOM.
I'll have to do some assembling in order to check if changing this setting solves the problem. Will give an update if i've tried it.
Dave
ali
1-Newbie
1-Newbie
(To:dbreen)
i tried all combinations of COMP_ASSEMBLE_WITH_INTERFACE and COMP_INTERFACE_PLACEMENT.
I did not detect any improvement on loading time...
StephenW
23-Emerald II
(To:ali)
When using automatic component placement on large assemblies it can take a significant amount of time for the system to find potential assembly placements. This only improves time to assemble components, it doesn't improve overall assembly loading time.
I suggest turning off the automatic place option
comp_assemble_with_interface NONE
