Mirroring quilt and then merging overlapping error
ZB_10997444
1-Newbie
I am working on this surface that is part of an assembly. When I try to merge the quilts after the mirroring (in FRONT plane) i get an error of overlapping. I am struggling to find the overlap/how to resolve this issue. My files are linked (assembly, reinforcement plate and upperhood). The reinforcement plate is using the same geometry as the upperhood. The issue occurs in the part called: reinforcement plate. Any help is appreciated.
I am using the student version of creo parametric.
1 ACCEPTED SOLUTION
kdirth
20-Turquoise
(To:ZB_10997444)
Not many of the professionals here will be able to open files from a student version.  Screenshots of the model with the model tree would help us understand your situation.
1 REPLY 1
kdirth
20-Turquoise
(To:ZB_10997444)
