Renaming a Surface (not a feature)?
maccount
How do I rename a single surface? I know how to rename a feature, that's not what I am looking for. I want to select a surface (in this case it is one of many created by an extrude feature) and set the name to my chosen value.
I know this can be done because the EFX stuff I am working with has renamed surfaces. Just need to know how to do this.
Solved it. File - Properties - Names (change)
What rev are you running, 5.0? As of WF 3.0 the picks are still Edit/Setup/Name/Other.
Yes, WF5
