Stylized line weight in 2D drawings
Nairn
8-Gravel
Hello, I was wondering if anyone knew if Creo Parametric is capable of producing drawings like this:
Not sure which this drawing was produced in, but it follows the conventions I was taught during technical draftsman classes in high school, and technical sketching classes in uni. Key thing I would like to achieve- the boundary lines are thicker than internal lines, and if there is a way to make a bottom or part-overlapping edge thicker than standard outer lines that would be great too. Haven't seen anything online that relates to this. Not sure if it's even possible.
Thanks!
1 ACCEPTED SOLUTION
MartinHanak
24-Ruby II
(To:Nairn)
Creo Parametric is not capable of producing drawings like this. I guess the picture was created in Creo Illustrate.
Martin Hanák
2 REPLIES 2
MartinHanak
24-Ruby II
(To:Nairn)
Martin Hanák
Thanks Martin, I'll take a look at Creo Illustrate.
