how to select a sub-assembly on screen
nrollins
1-Newbie
Hi all,
I do like the smart filter - but it is far from perfect. You would think that in an assembly environment the smart filter would start with sub-assy's and then part>feature>geometry...
Is there an easy way to select a sub-assy by picking on the screen?
-Nate
1 ACCEPTED SOLUTION
rohit_rajan
(To:nrollins)
try this:
select a part from the sub-assembly on screen then RMB...the last option i guess is "select parent"..that should select the sub-assembly.
2 REPLIES 2
rohit_rajan
(To:nrollins)
try this:
wow - thanks. I am ashamed that I did not find that - live and learn.
