Can I get a callout for a thru hole without the word "THRU" without erasing the word manually?
If you're referring to standard (spec driven, UNC, UNF, ISO) hole callouts, you can customize the note callout via the .hol files.
See http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/part_modeling/part_nine_sub/Formatting_Thread_Note… for help on editing the .hol files to customize the note callouts based on hole feature options.
Dan N.
Check your settings because I created a new part, added some holes, created a drawing and when annotated, only got the diameter symbol and the diameter value.
Creo 2 m220
Dan N.
Thank you Daniel, it was precisely what I needed!
