Creo Schematics: Run the two applications (Full and Lite) next to each other
NC_4023452
6-Contributor
Can I easily switch between the Lite and the Full versions? The end users want to be able to use both for a while
1 ACCEPTED SOLUTION
NC_4023452
6-Contributor
(To:NC_4023452)
The problem is solved. It's a setting in the install procedure.
3 REPLIES 3
NC_4023452
6-Contributor
(To:VladimirN)
I know the different between the Full and the Lite but I want to run them together on one PC.
So that I can choose if I start the Lite or the Full.
NC_4023452
6-Contributor
(To:NC_4023452)
