Creo View Express 10 Installation File does not work
Meike
I've downloaded Creo View Express 10 more than three times from
https://www.ptc.com/en/products/creo/creo-view/extension-express-download
Unfortunately, the installation could never be started.
I always get the message "This installation package could not be opened. Have the application manufacturer check whether this is a valid Windows Installer package."
I use Windows 10 Professional
kajohnson
(To:Meike)
You can resolve the issue by renaming the executable from  .msi to .exe . I will have the download page updated as well.  When we renamed the file extension, the installation proceeded correctly.
Thank you for your patience with us.
Kathy
6 REPLIES 6
kajohnson
(To:Meike)
It seems that the MSI had been modified. We expect to have the Creo View Express for 10.1 posted there by the end of the day.  Stay Tuned.
Kathy
kajohnson
(To:kajohnson)
The Creo View Express for 10.1 is there now and we have added the Checksum for it so that you can always confirm you have the correct file. That should help going forward.
Thanks for letting us know!
kathy
Meike
(To:kajohnson)
I'm so sorry, but it doesn't work.
Checksum ist the same but Microsoft says that it is an incompatible program.
kajohnson
(To:Meike)
Kathy
Meike
(To:kajohnson)
Rename to *.exe is the solution, thank you.
Note for you: The help text "Download *.exe" is now displayed on the page, but the *.msi file is still downloaded.
kajohnson
(To:Meike)
The Creo View Express download page will now download the executable with the correct file extension. Problem solved 🙂
