Is it possible to use Diagram to autoroute in Parametric?
aturcat
6-Contributor
Extract from tutorial :
About Autorouting
In order to automatically route cables or wires without manually choosing From and To entry ports, you must establish a logical reference. The reference can be to an XML file that is exported from PTC Creo Schematics, a Diagram file or a wire list text file in a supported format.
Does this mean that is it possible to autoroute wires in CreoParametric using logical data from CreoDiagram?
I'd greatly appreciate an answer, thank you!
1 ACCEPTED SOLUTION
I believe you can, but I'm not aware of anyone who has used Diagram in about 10 years. As a matter of fact, I believe it goes away in Creo 5.0 released in March.
Dave Martin - dmartin@creowindchill.com - https://www.mcaeconsulting.com
1 REPLY 1
