I am trying to use the Creo Simulation Wizard. I am running into a problem with the domains. I am trying to select my singular part as the solid domain for external fluid flow but it will not select it and will not create a bounding box. Any ideas what I am doing wrong?
Nevermind I forgot to press oK
