How do I define a load that rotates from 0deg to 360deg from the original position in Creo?
CZ_10454112
3-Visitor
Hello everyone,
I would like to simulate the stress vs. load angle in Creo. Instead of creating individual load set for every 20 degree, I would like to see if there is a way to define the load with the parameter relation, and make Creo run the analysis for with a new load for every 20 degree.
The load magnitude will stay the same, but the direction will change. Thank you so much!
example att.
Thank you so much!!
Thank you so much for sharing the example! I was able to mimic your steps on my model :D.
I also added some points for measurements, and I would like to export the values from the analysis. I don't see the .csv file of these values saved like what a static analysis does. If possible, would you mind showing me how to get the values out? Thank you so much!
