How to calculate the fan air volume. Creo Flow Analysis CFM
SZdore
11-Garnet
SZdore
11-Garnet
(To:SZdore)
cfdgeek
(To:SZdore)
Hi
Please create an interface at the outlet of the fan and turn on volumetric flow rate output there. or you can monitor the whole domain flow outlet.
cfdgeek
(To:SZdore)
Create a bc patch and then go to the output session.
SZdore
11-Garnet
(To:cfdgeek)
Thank you very much, but how do I view this result parameter.
cfdgeek
(To:SZdore)
Please use xyplot. Please go through the first tutorial case, you will know the details. Thanks
