Live Simulation only uses GPU when rotating model
RW_6737394
2-Guest
Hello, I am trying to render a simple fluid flow simulation in Simulation Live for Creo 9.0.1.0.
When I add particles to the display it runs at about 2 FPS, this is with the Performance options set all the way to the left for "Speed". At this time, Creo is using 0-2% of my GPU.
However, what is interesting, is when I rotate the model, the GPU usage jumps up to 60-70% and the FPS is smooth (closer to 30 FPS or more).
I want to be able to have this speed and quality of animation without having to continuously rotate the model. Is this possible?
0 REPLIES 0
