Remote desktop connection using AE licenses
kregimbald
9-Granite
My pc at the office has a locked license. When I access my office pc from my home computer apparently I am using a floating license.
So basically I am using both locked and floating licenses. Consequently, less licenses available to other users.
Why does the license type change when accessing through VPN? I am connecting directly to my office pc where AE is installed. Should it not use the locked license?
Arbortext versions 6.0 and higher use the Flex licensing mechanism. Node-locked (fixed) Flex licenses cannot be used with remote desktop connections. Therefore, your application is looking for and using a floating (concurrent) Flex license when you are remoting in to your machine.
Do you use the styler version of editor? I find that I use our copy of styler and if I open a topic from the map it opens it in editor. Which uses up a locked version of styler and a floating editor.
Bryon
