Default options when Generating Report in Model Manager should be configurable
In the BOM Editor in Model Manager you can generate a report.
The different options are always the default values.
It should be configurable to change the default values, cause now you always have to change them again.
OK, you can store a Report Configuration, but the number of clicks to select a Report Configuration is as many as changing these options every time.
Other option is to make the Report Configuration selection available directly in the BOM Editor UI.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
