How can I select all dimensions and make them strong
ptc-6574380
I have a lot of weak dimensions I need to change. Can I change them all al once?
TomU
(To:ptc-6574380)
Yes, change the filter to "dimensions", window select them all, then press CTRL + T
TomU
(To:ptc-6574380)
Mahesh_Sharma
22-Sapphire I
(To:TomU)
Christian,
Does the information from Tom solve your issue?
CTRL+T didn't seem to work for me. Right click and strong and / or lock did though after windowing them all.
Which version/datecode of application are you using?
