Toroid inductor coil
kmark
1-Newbie
I like some help with creating an inductor toroid coil as seen here in the attached picture.
7 REPLIES 7
TomD.inPDX
(To:kmark)
How close to accurate and detailed do you need it?
This is normally overkill, but it would look something like this:
Many patterned sweeps and a few point-to-point datum curves.
Creo 2.0 file attached.
VladimirPalffy
(To:kmark)
Dear Kevin
Many years ago I created this model of Toroidal Coil
Try to investigate the model tree and you will see that I have used only curves and Sweep feature - it is not necessary to create Pattern feature.
If you need to manage number of coil thread - you can easy change the Parameter (in my example - POCET_ZAVITOV (slovak name)):
Here is the Tutorial for you: User defined springs
Vladimir
Best Regards,
Vladimir Palffy
Vladimir, is there a reason you don't prefer patterns?
I considered two things when posting this method;
  • The pattern break at the crossover wire.
  • The level of complexity to construct the model.
I like the way you intersected the surfaces to create the sweep trajetory but it leaves little room for the interuption requiring two such features.
In the end, the patterned model with a few sweep sections seems simpler in this particular case.
Video Link : 4002
Hi Antonius, I like the pattern feature and sweep feature too - PTC Creo is my favorite.
Your model is really good, I like it too.
I wanted to show the other method for you and others members
Vladimir
Best Regards,
Vladimir Palffy
Thank you to both, Vladimir and Antonius for helping with the Toroid feature creation. You are the best.
Kevin
VladimirPalffy
(To:kmark)
Hi Kevin,
You are Welcome. I'm glad if I can help
Vladimir
Best Regards,
Vladimir Palffy
