Allow double click edit of dimension or tolerance value in drawing
Please add back the ability to double click edit a dimension or it's tolerance while in drawing model using Creo Parametric 3.
Currently in Creo 2 you can double click on a dimension (parametrically driven) and edit the value of the dimension.
Using Creo Parameteric 2 you have to use 4 mouse clicks to edit the tolerance value.
Using Creo 3 you have to use 4 mouse picks to edit the dimension value or the dimension tolerance value.
Please change it so when you double click on the dimension main value or the tolerance value you can enter a new value for the value you double clicked on.
Creo Parametric 2  ( 2 clicks )
Creo Parametric 3  ( 4 clicks )
Note: this ideas has been marked as duplicate, please see Edit the tolerance of a dimension in drawing by using double click
13 Comments
Dale_Rosema
22-Sapphire I
ryankelley
1-Newbie
Thanks, Dale. I've marked this idea as 'Duplicate'.
Anyone who's interested in helping shape this idea should provide their votes and feedback (comments) here: Edit the tolerance of a dimension in drawing by using double click
TomU
23-Emerald II
This works as requested in Creo 3.0 M030.  See video below.
Video Link : 6030
(Not sure what's up with this video.  I've attached MP4 and AVI and neither one appears to be showing up...)
Marco_Tosin
Tom,
I see your video without any problem.
danderson-3
11-Garnet
He needs to modify his idea discription to include double clicking the main dimension value.
We have lost that fuctionality going from Creo 2 to Creo 3.
danderson-3
11-Garnet
Tom,
When I left double click click (only left button) on the dimension I get the format text tab. This is using Creo with no config settings, straight out of the box.
What are you exactly doing to get it to edit the value?  Are you using pre-highlight, what tab do you have enabled?
Creo 3  M030
Don
danderson-3
11-Garnet
How to remove the flag that this is a duplicate idea as it's been confirmed it's not a duplicate idea. Those that go to Creo 3 will soon find out it's not!
StephenWilliams
22-Sapphire III
You should tag Ryan Kelley‌ for help on getting it changed.  You'll likely need to make your case as to why it is not a duplicate.
danderson-3
11-Garnet
Ryan,
Attila Tempfli agrees with me in that my idea's not a duplicate idea.  could you please remove the duplicate tag? Both are trying to address 2 different issues.
Don Anderson
ryankelley
1-Newbie
Video is displaying just fine.
ryankelley
1-Newbie
I've removed the duplicate tag for this Product Idea. Please let me know if you need anything else.
MartinHanak
23-Emerald V
in CR3 M070 (with default Creo config.pro, only) in Drawing mode, Layout tab active:
  • if I doubleclick tolerance value => edit combobox opens
  • if I doubleclick leading 1 digit in 100 value => edit combobox opens
  • if I doubleclick trailing 0 digit in 100 value => Dimension Properties dialog box opens
  • if I doubleclick dimensioning line with arrows => Dimension Properties dialog box opens
  • if I ZOOM IN dimension and doubleclick any location on dimension  => edit combobox opens
MH
danderson-3
11-Garnet
Looks like they have made improvements with M070 per Martin's reply above.
Not sure how to close this one?
