Creo Plastic Part Design Tips n' Techniques
100% helpful (1/1)
Check out this video on Plastic Part Design from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Tom Quaglia (Creo Segment Sales )
Comments
Webcast Q&A
Question from ChiragCan you do draft check in two directions at the same time?  Molding part requires action in different directions.  Good to see all at once when doing reviews.
Answer:  No, but you can change the direction of the draft.
Webcast Q&A
Question from DavidIs there any way to not show (turn off) the first instance of a pattern?
Answer:  Any and every item in the pattern can be toggled on or off.
Question from DavidThat is not the case for Creo 4.0 M120 that I am using.  The first instance cannot be toggled off.  Can you provide many examples of 4 not allowing first instance of patterns not being able to be toggled off?
Answer:  Pattern Fill - you can remove the first.  All other patterns, in 4.0, you can't remove the first but you can with a flex modeling remove.
Webcast Q&A
Question from RajeshThe draft hinge can be a curve?
Answer:  It can be 3D but it does need to be a surface for a draft check.  The draft creation can be relative to a curve.
Version history
Last update:
‎Nov 17, 2021 05:21 PM
Updated by:
Labels (1)
Tags (1)
