Export dxf in same units as .pvz file
Creo View
If you Export a pvz file (from Creo View)  - with save current view as --> dxf - the Units in the .dxf are automatically changed to Inch.
would be nice if the Units would be the same as in the .pvz file or the Units are configurable.
4 Comments
GabrielZaha
What version of Creo View are you using?
Creo View 2.0 M040 has this functionality:
Is available in CreoView Standard and CreoView MCAD. Save Current View as ... is not available in CreoView Express or Lite
phinterdorfer
Currently I`m using Creo View 3.1 F000, as PTC advised me to use the neweest Version.
The dxf should be saved from a 3D Model.
Is your screenshot created from saving a drawing as dxf-file?
GabrielZaha
That's right. The screenshot was created from saving a drawing.
And the option to select the units is missing when working with model files.
olivierlp
Community Manager
Status changed to: Archived
