Connect Robot Fanuc To Kepware Server
Arnaud_T
3-Visitor
Is there any possibility to connect a Fanuc Robot to a Kepware Server by an ethernet connection?
@at_10782646
The Kepware Fanuc Focus driver can read Axis Data Values. Here is a link to the page in the help file that covers this:
https://www.ptc.com/store/-/media/kepware-store/en/manuals/fanuc-focas-ethernet-manual.pdf#page=49
*Chris
Thanks a lot and I already saw them.
For the Focas Ethernet, I understood that it is dedicated to Fanuc CNC and not R30iA or B Robot Controllers but perhaps I'm wrong.
And the second topic, I'm not sure with that solution I could retrieve the 6 axis angular values because this is my target, not well explained in my 1st post, sorry.
@at_10782646
*Chris
Thanks for your reply but Focas connectivity, as I understood, is dedicated to CNC Fanuc application, is it also compatible with Fanuc Robots?
