Property editor
RJ_9772751
2-Guest
Property editor
Hi everyone,
I have KEPServerEX6 and I need to change options in property editor. When I change option and click apply settings is confirmed but when I runtime connect the setings change to previous. Tell me why?
Greetings RJ_9772751,
Please take a look at the following knowledge base article relating to this:
https://www.ptc.com/en/support/article/CS273673
(If you are prompted to login you may use your MyKepware credentials.)
BRgds,
KC
BRgds,
KC
