Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I am using Creo Parametric - Release 2.0 (connected) 2.0 M250
Harness Bundling Failure and Not able to identify the failure Reason "The wire has more than 0ne disjoint". Need help to resolve this issue and want to know how many wires can be Bundle/routed in a single harness model.
Here are the errors that I faced The wire has more than 0ne disjoint
