Suggestions for future releases of Mathcad
0 Kudos
Since Mathcad cannot push dimensions into family tables, it doesn’t really help us.  Can you build the capability into future versions of Mathcad so it will work with family tables in Creo?  It would also help a ton to be able to drag and drop calculations like in excel.  In excel, it is very efficient to calculate the required wall thickness for a family of cylinders with 5 different bore sizes for example and drive the Creo family table.
2 Comments
Georgios
1-Newbie
Yes, Mathcad should become the most integrated editor for all Parametric Creo and Creo Elements features.
Should generate data for mathematical curves to help the design intent, should be used to fulfil Family Tables cells data, to generate tables for Simulation as defining a load profile over a beam or over time (direct way to start Mathcad from these features, not import a file generated previously) or... in general to be able to present in its plots all the Pre and Post Processed graphs of Creo Simulation, to generate the material's profile with a σ/ε graph.
olivierlp
Community Manager
Status changed to: Archived
