Home Use LIcense
ptc-1416740
Home Use LIcense
I just upgraded to the full Edition to MathCAD Prime 9.0 from MathCAD express (MyCommerce Order Number: 860697573 ). I received a license file and I successfully upgraded my MathCAD Express to the full edition on my work computer.
Does my single user license for the full edition entitle me to a HOme use license as well?
Theodore F. (Ted) Wiesner, PhD PE
Professor Emeritus
Department of Chemical Engineering
Texas Tech University
Articles:
Articles:
ptc-1416740
(To:VladimirN)
Hi Vladimir,
Many thanks for your quick response to my post.
In going through the procedures at the links you posted, I think all I did was transfer my work license to my home computer. Now I can work at home but not at my workplace.
I think the problem may be related to the fact that my license manager does not show home use licenses available. However, the home use policies do indicate that a home use license comes with a single user license.
Do you know how I can procure the home use license?
Ted
 Hi Ted,
1. I would recommend contacting the seller who supplied you with this license to clarify this.
2. Also you can create a new Case here - "Mathcad Support Center": https://support.ptc.com/support/mathcad_supportCenterOpt.htm
ptc-1416740
(To:VladimirN)
Hi Vladimir,
Again, thanks for your help.  I found out that my home use licenses were not showing up because I didn't click the "+" sign to the left of the product column. Clicking it exposed 2 home licences.
Best regards,
Ted
I'm glad you solved it.
