Installation issue with Mathcad Test version
NJ_10337397
I can not install the test version of Mathcad. The Installer was send to me over my email adress, after login on the ptc website.
When i start the installer, the files will be extracted, but then nothing happends. The windows with the installation menu doesnt pop up.
Thanks for help
6 REPLIES 6
LucMeekes
(To:NJ_10337397)
Did you follow the instructions?
https://community.ptc.com/t5/Mathcad-Installation/Step-by-Step-Installation-Procedure-for-Mathcad-Prime-8-0/td-p/789358
Especially: "execute/run pim_installmgr_mathcad.exe,  run as an Administrator."
Yes, i also confirmed the UAC.
1. What Windows OS are you using?
2. Try the following tips:
I am using windows 10 Home.
Unfortunately none of these tips works for me.
I also dont even get an error message. It simply doesnt happen.
Thanks for help
Hi @NJ_10337397,
Can you check and confirm if there is any anti virus/firewall installed on the system that may terminating the setup.exe before it gets executed
Vipul
