I am using Mathcad Prime Release 9.0 and Datecode9.0.0.0
Retype serverlicense adress
Here are the errors that I faced
We have users that needs to retype the serverlicense-adress once or every other week, it is like the program don't remember what you typed in.
All other functions i working so it is only this that we have some issue with, have been so since summer.
I have the program also installed but don't seams to be an issue for me, but i don't use the program i that way, i just maintained the server and our license.
Have you heard about this before, do you have some recommendation what we could do?
Best Regards
Tomas Eklöf
Service Responsible
Hi VladimirN
I think i got it resolved, i just change the serveradress in the registry,
typed the right serveradress there, before it said localhost:7788.
So when the user change the adress in the program it worked for one week, and then it switched back to localhost again.
Now it have been stable for 3weeks so i hope it works now.
Best regards
Tomas
I recommend you open a new Case here - "Open a Support Case": https://support.ptc.com/apps/cs_loggers/case_logger/auth/ssl/log
Hi VladimirN
Best regards
Tomas
Glad to hear that!
