Below is the step by step process listed on how to install Mathcad Prime 8.0 -
Refer URL and fill up the Mathcad Express Free Download form. Once filled, submit the form.
2. Post submission an email will be triggered to your email account used while filing up Mathcad Express Free Download form.
Important Note:
Now, lets start with the installation process - So, refer email from PTC with the link to download the Trial Version for Mathcad Prime Trial Edition execute/run pim_installmgr_mathcad.exe, run as an Administrator.
1. Select #Install new Software and Click on #Next
2. Select #I accept the license agreement and Check the box for Export agreement then click #Next
In the Application Selection screen, Change the installation directory, if required. Else, Prime 8.0 will get installed in the default location shown
4. Select #Next
This will trigger a new window "Customize Selected Applications".
Customize Selected Applications:
Use this to Install Standalone Converter with Mathcad Prime 8.0 and local help center in multiple languages also, to modify the windows shortcut settings for Prime 8.0. Choose list of applications need to be installed. By default, all the applications are checked.
5. Select #Finish
You have successfully installed Mathcad Prime 8.0!!!!
