file sharing
岸昂_10056789
file sharing
In the student version of the product, I can't open a file I worked on in one computer on another computer. Is there a solution?
First you need to compare which versions of the programs you use on different PCs.
Thanks for the reply.
As I looked into it, I found that the product had "node-lock" in the product name, so I could not operate it from other pc's.
Thank you for trying to move to a solution.
