30 day trial license will not activate
getting error: (-103) Cannot checkout an uncounted license within a Windows Terminal Services guest session.
I am working remotely to the computer Prime 7 is installed. Do I have to go into work and access the computer to finish activation? Will I be able to use the trial remotely?
If you are accessing a machine over a remote desktop session, you need a Floating type of license.
P.S. Related materials:
