problems with combo box
CY_10812282
8-Gravel
Good evening community, I have a problem with the combo box tool, it turns out that I want to use this tool and I get the error that I show below, Install Mathcad Prime 8.0.0, on a Windows 7 operating system, if someone can give me a reason for this error.
Translated the text from Spanish to English using google translate:
Subject: problemas con cuadro combinado
Body: Buenas noches comunidad, tengo un problema con la herramienta cuadro combinado , resulta que deseo utilizar esta herramienta y me aparece el error que muestro más abajo, Instale Mathcad Prime 8.0.0, en un sistema operativo windows 7, si alguien me puede dar una razón por este error.
- By community moderation team
1 ACCEPTED SOLUTION
LucMeekes
(To:CY_10812282)
Buenos diaz.
The error message is handled here: https://community.ptc.com/t5/Mathcad-Installation/Error-quot-An-Unhandled-exception-occurred-on-the-dispatcher/m-p/706410#M19
Pay attention to language: It appears that the error can occur if the language version of your Prime installation is different from the language of your Windows.
You can start Prime in a different language, see here: https://community.ptc.com/t5/Mathcad-Installation/Switching-language/m-p/744327
Succes!
1 REPLY 1
LucMeekes
(To:CY_10812282)
Buenos diaz.
Succes!
